Have you tested the ACC on the motorway yet? Let us know if you have issues when overtaking cars, often it will slow you down. Again, issue is that it appears to be set up for LHD, but (again) only sometimes!!I picked up my Formentor yesterday morning and have already had a couple times that I couldn’t open the car using the keyless entry. I have keyless entry on my Seat Ibiza for the last two years and never had an issue with it. At one point I couldn’t even open the boot by hand even though the car was unlocked so had to open the boot using the button on the key fob. I had the 110mph speed limit show on the. Dash board but happy to say the acc worked correctly. My car that was built on the 6th April has software version 1790 and my Formentor is a VZ2 310ps.
It is 110 mph that shows as the speed as you also get a red marker displayed on the speedometer showing the speed. When it happened to me yesterday I was driving at 68 mph on the M25 so if it changed to kph the speedometer would have changed also. On the same journey my car displayed 90 and 45.It’s not 110 mph it’s kph.
Not sure why but this is a common infotainment fault across VAG for RHD cars that sometimes show the speed in KPH.
To be honest I’m basing my “assumption” on the following, 110kph is pretty much the euro equivalent of our 70 mph, likewise 90 vs our 60 and 45 vs our 30. I was made aware of this on numerous Octavia forums where they have this issue also, the car software still appears to have LHD ghosts in the machine. See also issues with aircon sync and also some issues with ACC overtaking of cars on the left. (Although in some cases the latter can be caused by people turning lane assist off, which affects ACC performance)It is 110 mph that shows as the speed as you also get a red marker displayed on the speedometer showing the speed. When it happened to me yesterday I was driving at 68 mph on the M25 so if it changed to kph the speedometer would have changed also. On the same journey my car displayed 90 and 45.
Hi do you have lane assist active when the car does this?Have you tested the ACC on the motorway yet? Let us know if you have issues when overtaking cars, often it will slow you down. Again, issue is that it appears to be set up for LHD, but (again) only sometimes!!
Ah ok, what I described is a known fault elsewhere, but this looks like it’s part that and part something more.No, speedo doesn't change to km. Only sign display is showing in km. So you may see often: 45, 80, 110.
It also randomly picks up speed limits from nowhere, showing 40 when it's 50 on the road and there was no sign to read incorrect speed.
I had lane assist on when it happened.Hi do you have lane assist active when the car does this?
I would assume it uses satnav data for this.No, speedo doesn't change to km. Only sign display is showing in km. So you may see often: 45, 80, 110.
Ah ok, what I described is a known fault elsewhere, but this looks like it’s part that and part something moreNo, speedo doesn't change to km. Only sign display is showing in km. So you may see often: 45, 80, 110.
Hmm it’s an odd one isn’t it. I only ask as I’ve seen this on the Octavia forums and one thing that caused it was people weren’t happy about the “aggressive” Lane Assist so switched it off. This seemed to throw the ACC, but it sorted itself when Lane Assist was re-engaged. Hopefully the software updates are moving the car towards a glitch free product.I had lane assist on when it happened.
Yep, but this isn't related. The dash shows image of a car to the left when slowing the car. Now in my previous Golf this would occur if you were 'undertaking' a car on your right in, say, slow moving traffic on the motorway - understandable. Hence it appears set up incorrectly for RHD modelHi do you have lane assist active when the car does this?
Thanks for that, great specifics. Definitely a car wrestling with its LHD roots.I paid extra attention to it yesterday. I did 300-350 miles. Car switched road sign display to km on specific road, both ways. As soon, as there was sign, it read it and switched back to mph. So switching to road signs in km might be related to missing information on the map and inability to find signs to read.
When sign was showing in km, then ACC was discovering cars on the left. So it's definitely related to each other.
Tried reporting the issue to Cupra HQ, but they're insisting on me booking it in with a dealer. I've said they won't have a scooby, but they said its the only route to getting this resolved. Not enough of a concern for me to do that, as otherwise I have no issues and the car is spot on.What Agnes described sounds like they built the car for LHD (makes sense) but forgot that when you are in a RHD country, fallbacking to satnav data should still use mph and allow overtaking on the right. It's like they forgot that specific part of the software.
I urge you guys to report this to Cupra - perhaps they can push an update that will solve this for your RHD cars. Imagine a bunch of engineers in Wolfsburg working on their software, none of them drive a RHD car and probably never find these type of bugs. It's appalling that it happens but best to try and resolve it.
Good call.I paid extra attention to it yesterday. I did 300-350 miles. Car switched road sign display to km on specific road, both ways. As soon, as there was sign on a road, it read it and switched back to mph. So switching to road signs in km might be related to missing information on the map and inability to find signs to read.
