Right, after fitting my shiney new Boost Gauge it appears that I'm maxing out @ 4psi.
I've checked ALL of the pipe work, and can't find any leaks.
I've read most of the threads about N75 valves, and wanted to ask the question...is it possible that the valve is up the swanny, and not allowing full boost?
Secondary question following the above, if I have to replace the N75 what are the characteristics or differences between the std N75 & the N75-J?
Cheers in advance peeps!
