LC 180 AUQ boost
Sl1ced
797
404
As above guys seems to vary model to model but mine according to the gauge I picked up is peaking boost at 10psi. Also I’m not sure what the sound is meant to be like only having a diesel to reference it too but it’s a bit hissy, ima re test my dv later on with a vaccum pump and see if it’s holding pressure. Wanted to stick the feelers out
Sl1ced
797
404
Cheers mate ima test the dv again with a vac pump, then may look into the 75
Connor H
1,015
498
Essex
I peak at 12 and hold at 10 (mods no map)If you're peaking at 10psi and holding then id say your DV is fine , if it was randomly dumping boost or dropping pressure on boost then i'd say its worth checking. I changed mine to a forge but the OEM is bullet proof
Sl1ced
797
404
I still have the old revision though. Not sure if it’s failing under boost I’ll check it anyway.
