Struggling to find definitive information on this from searching so thought Id ask the question:
I'm thinking of fitting LCR brakes (definitely fronts and probably rears too) to my 2004 LC (non-R) with standard 17" wheels - going for the stealth look
Can anyone confirm that the calipers will go straight on the LC hubs? Front discs are both 312mm I believe but are LCR ones are thicker?
On the rears I notice the plates (not sure what the correct term is ) behind the discs are only just larger than the current discs, so I assume these need swapping also when the rears are swapped?
Also do the standard LC hoses connect up to the LCR calipers? - mind you I may well go for some goodridge jobbies.
Finally can I keep the standard (5 spoke) 17" wheels if I fit appopriate spacers (and if so what size?) or am I forced to start looking for some new wheels?
