LCR No boost!!! Limp mode?
Loony R
Quattro ist fur sissies
Nov 23, 2007
243
Rossendale
Hi guys
Drove down Cornwall and the last few miles the car list all boost, no noise, no bang, nothin just refuses to boost. No lights on the dash either so disconnected the battery overnight and still no change?
Can anyone help?
Pagin
Numpty
May 19, 2013
70
Derby
How high does it rev? Is it capped, or will it go all the way? If it revs and there's no boost, I think you've got a massive leak, as a turbo has no choice but to boost.
Could be a dodgy recirc valve?
Loony R
Nov 23, 2007
243
Rossendale
Witt rev all the way up no problems. No sound of escaping boost or the turbo spooling so not a boost leak.
Loony R
Nov 23, 2007
243
Rossendale
Cheers, all pipes are on and secure. Kinda stuck down here till Monday so can't really check owt else?
andycupra
status subject to change
or just unplug the maf...
(ESP light will come on, and you will loose Traction control while the maf is unplugged)
it will run with slightly safer default settings using difference data, but would allow you to determine if the maf if the issue or not if it boosts ok unplugged.
Loony R
Nov 23, 2007
243
Rossendale
Found the problem. Maf, and n75 were fine
Took tip off the turbo and it spun nice and freely. Checked the actuator to see if the wastegate was stuck open to font the two lock nuts had undone leaving the gate wide open!!!!
Closed the gate, nipped up the nuts and hey presto! BOOOOOOST!!!!!!!!
Cheers for help tho chaps
