Last night when I pulled up , lights on dipped, when I turned engine off they seemed to get brighter, tried it again this morning and it definitely does..... Wtf is that all about? They do not move so its not the auto levelling.....
Probably this morning as it was peanut smuggling weather, the heater, hrw & mirrors would have been on, last night car had been on quite a run so bit different, just seemed strange. Checked Passat (standard halogen with nightbreakers) tonight and didn't notice a change when I switched off. I'll keep an eye on it.Other electrics causing a current drain ? Heater , air con , rear heated screen ?
I know led's current drain is minimal but must be affected by the current available.
I've raised mine by 1 turn. No dazzle, better range. Set very conservatively at the factory and not reset at pdi
Is this an easy job ? Mine seem waaaay too low on the road... !
Thanks.... off to find a wall !![]()
