Lowering confusion
Paul_Devon
Ive just put some 18s on my 2002 Leon cupra. It looks a little high so want to lower it about 40mm with just springs so that it doesnt look like a 4x4. A local car shop said that 40mm lower leon springs will only make about 10mm difference cos the cupra is lower than a normal Leon. Is this true?
Do I order 40mm lowering springs for a Cupra or order 60mm as its already lower than a normal Leon?
Sorry for the confusion. Also, whats the best budgetity make and wheres the best place to get them from?
Many thanks
Paul
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
40mm will do a decent drop, standard cupra springs are still as high as a boat mate. being a 2002 car regardless of mileage your shocks will not be in tip top condition though.
BEOWULF
I am BEOWULF !!!
Mar 18, 2006
1,186
I AM IN FRONT OF YOU
would go for coilovers or a a full set springs and shocks m8
i thought long and hard about this i was going to get just springs
then i thought my car is 5 years old the shocks will be no good
so i bit the bullet and went for coilovers
and fitted them myself.
PABLO ESCABAR
formally CUPRASMIFF
Jun 26, 2005
357
staffordshire
as said by all mate a full set a good coilovers is what you need and if you get the right ones you can adjust the ride and the hight to what ever you want, i did the same to my 2001 leon and now i just play about with it setting it up to how i want it:clap:
plus just gettting the spring will cause more damage to the OE shock that you will need new dampers in 6 months time anyway so why not:think:
bigjode
504
He's right, I put just springs on mne a few months back and the shocks are dying now!
And if you do go for shocks/springs, I put Eibach 35mm springs on mine with 18's and it sits very nicely, not OTT lowered, just a nice small, even gap around the wheels to the arches.
SWANSWAY CUPRA Dealership
