Hi, Got a new toy to play with. Am I right in saying you can log maf airflow to see how it compares to documented factory figures (well, figures using the 0.8 division formula)? The new toy is OBDEleven that offers the monitoring of the airflow, but I'm not sure the correct procedure to perform the logs. I've seen 'WOT' referred to, and third gear referred to. Putting the two together do I just boot it from a standing start,right up to end of 3rd gear? Do you cane it/redline it or does it not matter too much? Is a code reset and a lengthy drive required for the figures to be taken as accurate? Any help appreciated
