MILLTEK S/S Large Bore Downpipe & Hi Flow Sports Cat 200 Cell to fit SEAT IBIZA CUPRA 1.8 TFSi (6J/6P) 2016 on
BRAND NEW - RETAIL £918.51, SELL for £650.00
I can post this section of exhaust for an additional £15.00
Pipe Diameter O.D 2.76" (70.00mm)
Your original catalytic converter will typically have 400 or 600 Cells per square inch (CPSI) these original cats are restrictive in their flow typically allowing an open area of around 55-65%
Milltek Sport Hi-Flow Sports Cat which will be fully integrated into a large bore downpipe has only 200 CPSI
These cats have an open area of between 75-85% thus reducing back pressure substantially and increasing flow rates all very desirable for extracting more performance especially on Turbo-Charged engines.
All Milltek exhausts are designed, developed and manufactured in-house in the UK
Improved turbo spool
Large Bore Downpipe and Hi-Flow Sports Cat
Lambda probe positions remain unchanged from the original equipment.
Manufactured from 304 aircraft grade stainless steel.
Comprises of:
MSVW455 - Large-bore downpipe and hi-flow sports catalyst (200CPSI)
MSVW456 - Front Connecting Pipe
CHC73SS - 73mm S/S Exhaust Clamps (3)
Additional parts:
S/S Manifold clamp
Exhaust to Manifold Ring Gasket
S/S Lambda Extension
Comprises of:
Additional parts:
S/S Manifold clamp
Miltek Front Mounting Braclet & Sensor Socket-LAMBDA.jpg14.7 KB · Views: 19
Milltek Large-Bore Downpipe & Hi-Flow Sports Cat SSXVW417 (1).JPG366.7 KB · Views: 20
Milltek Large-Bore Downpipe & Hi-Flow Sports Cat SSXVW417 (4).JPG509.8 KB · Views: 17
Milltek Large-Bore Downpipe & Hi-Flow Sports Cat SSXVW417 (13).JPG476.7 KB · Views: 16
Milltek Large-Bore Downpipe & Hi-Flow Sports Cat SSXVW417 (15).JPG376.5 KB · Views: 19
