MoCool mixing with antifreeze
lucifer666
1,460
7
Cardiff
Was looking into different oils and coolents because i was made aware that there are certain types available to minimise heat buildup in the engine and some even claim to reduce internal temps.........very important with the 1.4tsi.
Anyway i foind mocool by motul which is a coolant which will reduce temps by 15deg celcius. Must be an advantage especially because the misfiring problem is related to heat. Motul also do a high temp oil too which would also help.
Question is it states that with mocool you mix 1 part with 20 of distilled water. But that des not offer antifreeze. But that can be added to. There are various types so which one would be compatible and how many parts antifreeze would be used per mocool/water mixture?
yea_good_1
LOVIN THE BOC
Sep 24, 2010
366
I'm glad someone bought this up I have been looking at the water wetter stuff that does the same thing hopefully someone has already tried it as I think it is worth a try.
Sorry Lucifer I can't answer your question I dont know hopefully someone can give us some answers
DEAN0
Old Git
Feb 1, 2006
5,439
Preston - UK
Not looked in to MoCool but you need to make sure it is fully compatible with the OAT antifreeze used in the Ibiza.
I think the Ibiza antifreeze is G12 or G13 and is OAT ( Organic Acid Technology ) which gives it it's long life properties.
