neal_h
just bought a leon 1m. first thing i done before i modded was checked to see what it was putting out so that i could fix it first. so i put it on the dyno and its putting out 133.3 at 5750rpm so then it plugged into vag which said i had a mechanical error with the boost pressure which i assume is the diaphragm in the stock dump valve is broken so i have ordered a forge split r which hopefully will arrive tomorrow and we shall see if that solves my problems. believe it or not that is the only fault code that came up apart from the lambda sensor or lack of one i should say. if anyone has any other suggestions what the problem could be let me know will post pics of car and dyno run when i hit 15 posts
forgot to say the engine was also smoke tested and no leaks inthe engine at all apart from the crankcase breather pipe but it had been cut.
neal
neal
