Hi guys, whent to the rolling road today to see if my car is putting out ATLEAST standard power with stage 2 mods, the problem ive been having is... sometimes it boosts up to 7 psi, then falls down to 5/6 and holds on my boost gauge.
Wallace per4mance say they think my n249 is done wrong, and is reason im loosing power
The power is 147.8 BHP for 5 psi with all the stage 2 mods (EXCEPT a ko3s, still running standard turbo) He said its not too bad power for it, but says it will cost £70 to fix my bypass for an hours labour charge!
I did not have ANY wiring on my engine atall when i got it, so i do not know how the standard N249 is wired up, so i CANT compare it to a bypass guide..
I really dont want to pay £70 if its easy enough.
what its like at the moment is..
ONE PORT ON THE N249 IS NOT USED, THE ONES I AM USING IS AS IF ITS GOING STRAIGHT THROUGH TO THE OTHER SIDE, NOT TAKING A THE ROUTE THAT GOES RIGHT/LEFT.
Any help will be appreciated! im desperate not to spend £70 for something i know i might fix in 20 mins?
- 1 vac line off inlet to the fuel regulator
- 1 vac line off the inlet, 'Y' Peices off, 1 peice goes to the dump valve from there, the other goes to the N249 Valve
- From the other side of the N249 Valve, i then have it going to the actuater, the nearest port to the drivers side.
- From the OTHER port on the actuater (passanger side) it goes to the turbo intake pipe
