New Battery info
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Guys, I think i'm in need of a new battery, mines flat this morning, cant think wy, i had the radio on yesterday for about 2 hours, not sure whether thats enough to do it, but it did previously go flat when i left the interior light on for 36 hours, without realising, and it had to then have a booster connected to the battery.
I've never replaced it since having the car, so see it as reaonable to swap.
I think i'm going to uprate the battery, and have looked at the Odyssey PC680, which i think a few people on here have used with no probs. I'm also going to use this opportunity to move the battery to the boot.
Is this battery ok to use, and to move to the boot?
I've found it for about £104 delivered at http://www.thebatteryshop.co.uk/pc680-odyssey-278-p.asp
Can anyone recommend anywhere else to pick them up from?
Whats the chances of being able to pick on up in a local store? As that would be easiest for me.
Any other recommendations?
Thanks Tom
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
Just cause its a bike battery doesn't mean it won't be good enough for a car mate. But as i don't know what spec battery is in the cupra as standard i can't compare them at the moment.
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
PC680 Odyssey battery
Voltage: 12 v
PHCA 5 seconds (Pluse Current): 680
CCA: 220
HCA: 370
MCA: 300
Dimentions: 185mm Long X 79mm Wide X 170mm High
Weight : 7.0 Kg
Warranty : 1 Year
cant find any other bsttry spec for an ibiza.
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
Standard battery specs
Power: 55 AH
Cold Cranking: 540 CCA
Length: 243 mm
Width: 175 mm
Height: 175 mm
Weight: 15.0 Kg
So that odyssey with 220CCA isnt up to the job of starting your car.
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Here's the spec of the odyssey from Odyssey website, which seems to indicate 680 cranking amps.
http://www.odysseybatteryshop.co.uk/i-ODYSSEY-PC680-12V-680-Cranking-Amps-I3107.html
ODYSSEY PC680 12V680 Cranking Amps Specifications
Drycell Battery
Without Metal Jacket
12 Volt
16 Ah @ 10hr rate
220 CCA
680 Cranking Amps for 5 Seconds
24 Minute Reserve Capacity
Cycle life @ 77°F 400 at 100% DOD
-40°F to 140°F Temperature Range
Replaces DYNA-BATT 5575B, 5575C
Dimensions(mm)
185 x 79 x 170
Cheers for the help guys, anyone else?
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
Yes but only 220 cold cranking amps which with our could winters is not going to be great for your car. The odyssey also has a lot lower aH rating than even the standard battery so it won't last for very long if you leave your lights on or radio on. And then definately won't want to start your car.
ian_cupra
has anyone got a guide for the battery in the boot job?? including the best battery etc.
interested in how you get on Forbez.
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Ian, if i get a Battery i'll do a guide, i've got one in prgress for another item, which i'll add soon.
Thinking about it though, its straight forward just lengthening the power cable.
ian_cupra
yeah true, its where to put the fuses, which battery to use and little things like that, what size cable (gauge size)
Nov 2, 2004
9,335
South Wales
Hardest part is gettin the cable through the car, and thats not even that difficult.
Heres my shopping list...
4AWG Amp wiring kit (cant be any thinner, 0awg is probably better but i havent had any problems)
2 battery terminals
Earth distribution block (2 x 4awg 4 x 8awg connections)
small length of 8awg wire to move the fuse pack whereve you want to.
Battery tray for boot
And thats it.
ian_cupra
cheers phil, take it the earth distribution block is for the fuse pack in bonet then? where you get it all from?
Nov 2, 2004
9,335
South Wales
dist. block is for the cable from the battery to split it, one to the starter motor then one to the fuse box.
