No radio?
vw_g60t
Hi, I have a 1998 ibiza 1.0 with a bee sting ariel, ever since i bought it the radio has never worked. it came with a cheap goodmans headunit in which there was no signal, i then bought a brand new Blaupunkt mp35 and when i installed it, i made sure the arieal lead (thick silver cable) was correctly inserted which it is - even still no signal.
However, i discovered another connector whilst installing the headunit, this was a weird 6 pin type of plug which the blaupaunkt headunit has connectios for (similar to a blaupunkt phono lead connector). Is this something to do with the arieal or am i right in thinking the bee sting standard seat arieal is only connected by the standard round arieal plug?
sorry about the essay,
cheers
CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
What is this 6 pin type plug like?? If it is like a blue box type thing then that is nothing to do with the aerial.
The signal should be alright with a bee-sting aerial cos i have one and its fine. Are you sure the aerial wire is silver??
vw_g60t
ye, the ariel wire is silver and is perfectly connected - do these ariels have a weak spot which causes a common failure or am i just unlucky.
Yes the 6 pin thing is a blue connector and my blaupunkt has a slot for it - what is it for?
