I know this has been covered a bit recently and I did search but want to explain exactly what I've seen today so as to be sure I'm on the right track, so here goes...
Was out for a drive today, kept getting caught behind slow Sunday drivers so didn't really get to open the car up much. After I'd been driving on and off for about 90 mins I was behind a couple of very slow moving cars on a 60mph limit road so when I got a chance to do so safely I pulled out, dropped into third and floored it to pass them.
As soon as the car got up to a few thousand rpm the oil warning light flashed about 6 times and three loud beeps, then disappeared again. This happened again a short while later but wasn't pushing the car as hard this time, then again as I was pulling in to Tesco off the roundabout at the entrance.
Checked the manual which said to check the oil level, which I did and it showed actually over the maximum mark. I haven't had to put any more in since I got the car and the last time I checked it the level was fine so figured this was because I'd just been driving about. Drove the car very gently home and left it for an hour before checking again but the level still looks a bit high.
I read a few posts that say to get the pickup in the sump checked/cleaned but given that the oil level looked higher than it should be is this still the recommended thing to do? I can't do this myself so it'll have to be the garage if so, should I get the car towed there or am I safe enough to just drive it there very carefully?
