Has anyone else had P0036 code issues and how did you solve the issue?
ian398 Jun 15, 2020 1 0 Jun 15, 2020 #1 Has anyone else had P0036 code issues and how did you solve the issue?
Leon20vt4 Active Member Oct 21, 2018 939 683 Jun 16, 2020 #2 ian398 said: Has anyone else had P0036 code issues and how did you solve the issue? Click to expand... Pretty sure that’s your 2nd lambda sensor heating element has gone bad. Fix it by replacing the lambda sensor after the cat. It should have a 4 pin connector and a 63cm or so long cable Sent from my iPhone using Tapatalk
