Park pilot unavailable - rear OPS retrofitted + RVC
Youngers
27
Hi all. I have recently retrofitted the rear ops system along with the rvc. I awas previously having issues with trying to connect to 10-park/assist to code, I have now resolved this as I am able to code. I have setup all coding and adaptions required to CAN gateway, park/assist and 5F units. However when I put my vehicle into reverse the screen switches to park pilot for a few seconds then advises 'park pilot unavailable' but the rear ops system continues to work via gong but nothing on screen.
Here is my current coding of my vehicle and one other thing I did notice was a fault is present for rvc no signal, also below. I have checked feed and quadlock for connections which are ok, so im actually stuck at this point with no idea what to do.
Code:
 Chassis Type: 5F (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
Address 01: Engine (J623-CZCA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HB    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H25 2328
   Revision: R7H25---
   Coding: 01190012232419080000
   Shop #: WSC 00049 770 00194
   ASAM Dataset: EV_ECM14TFS01104E906027HB 001004
   ROD: EV_ECM14TFS01104E906027HB.rod
   VCID: 6B80CE1AC308F67FE8B-803E
   CAN Converter 01:
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-ESP-V1.clb
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 63525000000074
   Coding: 20EE8A92242029700077060041C8240451249400608224F200210070C002
   Shop #: WSC 00049 770 00103
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033
   ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
   VCID: 4BC06E9AA348167F88B-801E
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5F0 907 426 R    HW: 5F0 907 426 R
   Component: AC Manuell    H03 1203
   Revision: 00001K09
   Coding: 00100004200100001000000000001000
   ASAM Dataset: EV_ACManueBHBVW37X 003128
   ROD: EV_ACManueBHBVW37X_SK48.rod
   VCID: 392C2452F9D494EF2A7-806C
   Fresh Air Blower Front:
   Refrigerant Pressure And Temperature Sender:
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0175
   Serial number: 01061600501296
   Coding: 0B000A424241027B0BA44000B10403081000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 015001
   ROD: EV_BCMBOSCH_016_AU37.rod
   VCID: 094C9492E9B4446F7A7-805C
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 5F2 955 119 A    HW: 5F2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 151006  041 0574
   Serial number:         151105071113
   Coding: 0BC5FD
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S3Y15M11D30H13M08S32
   Coding: 00095D
   Sensor For Anti Theft Alarm System:
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY1520130AM
   Alarm horn:
   Subsystem 4 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000064522729
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 G    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0056
   Revision: --------    Serial number: 39291533004835
   Coding: 0000250001
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_EPHVA14AU3700000 002024
   ROD: EV_EPHVA14AU3700000_AU37.rod
   VCID: 3D243042EDFCA8CF06F-8068
1 Fault Found:
12658704 - Databus
          U1121 00 [008] - Missing Message
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 66
                    Mileage: 3660 km
                    Date: 2017.05.23
                    Time: 16:24:10
Address 15: Airbags (J234)       Labels: 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 AS    HW: 3Q0 959 655 AS
   Component: Airbag VW20   013 0200
   Revision: --------    Serial number: 003SQPQQWYUF
   Coding: 98CCC000000000005C0000CC008800000065
   ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 0F78BA8A97D06A5FA43-805A
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 454 000 712 15
   Component: SideSensor_Df  008 0887
   Serial number: 3576U000000D1879B71M
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 454 000 812 15
   Component: SideSensor_Pf  008 0887
   Serial number: 3586U0000005CC70781I
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 454 800 612 15
   Component: SideSensor_Dr  301 0148
   Serial number: 3516R6A03F5080000003
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 454 801 212 15
   Component: SideSensor_Pr  301 0148
   Serial number: 3526R304D6B090000003
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 5 - Part No SW: -----------    HW: 454 801 711 15
   Component: FrontSensor_D  304 0149
   Serial number: 3556VCE4004090000007
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 GD    HW: 5Q0 953 549 F
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 14121504400681
   Coding: 1400
   ASAM Dataset: EV_SMLSKLOMQB 020001
   ROD: EV_SMLSKLOMQB_SK48.rod
   VCID: 7EA6F74EA07A73D75F5-802A
Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb
   Part No SW: 5F0 920 973     HW: 5F0 920 973
   Component: KOMBI         303 6420
   Coding: 27A402002980260001086A001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009046
   ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
   VCID: 698CB412C9F4E46F9A7-803C
Address 19: CAN Gateway (J533)       Labels: 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1243
   Revision: --------    Serial number: 0004359817
   Coding: 030100F42F085700EA000040000F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 013020
   ROD: EV_GatewLear_013.rod
   VCID: 79ACE452B95454EF6A7-802C
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Component: E221__MFL-PR6  H04 0130
   Serial number: 000000000B0502201115
   Coding: 002000
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185704001512193278
Address 42: Door Elect, Driver (J386)       Labels: 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
   Component: TSG FS        010 0031
   Serial number: 0000177590353
   Coding: 00100220C001040000001000
   ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 45D458A2852CE00F5EF-8010
   Drivers Door Rear Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0005
   Serial number: 00000000000008483862
   Coding: 2D0000
Address 44: Steering Assist (J500)       Labels: 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  125 1063
   Coding: 0103
   ASAM Dataset: EV_SteerAssisMQB 012140
   ROD: EV_SteerAssisMQB_VW31.rod
   VCID: 44D245A68E16D907491-8010
Address 52: Door Elect, Pass. (J387)       Labels: 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Component: TSG BFS       010 0031
   Serial number: 0000177956241
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   Passengers Rear Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0005
   Serial number: 00000000000008396894
   Coding: 350000
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Part No SW: 5Q0 907 357     HW: 6R0 907 357 A
   Component: LWR-ECU       005 0080
   Revision: --------    Serial number: --------------
   Coding: 048E000009000000
   ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
   ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
   VCID: 75B4E862954C308F0EF-8020
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 5QA 035 858     HW: 5QA 035 858
   Component: MU-S-ND-ER    H24 0245
   Serial number: SEZAZ2R0674384
   Coding: 04731001D70A000011111101008808002F0200D60120010046
   ASAM Dataset: EV_MUStd6C1TSAT 001015
   ROD: EV_MUStd6C1TSAT_SE26.rod
   VCID: 045285A6CE961907091-8050
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5F0 919 604 A    HW: 5F0 919 604 A
   Component: ABTm_Std2_Nav  H44 1031
   Serial number: SEZ8Z9RLM005LG
   Data medium:
   Subsystem 2 - Part No SW: 6P0 919 866 D    HW: -----------
   Component: ECE 2016  --- 0521
   Serial number: --------------------
1 Fault Found:
6720 - Rear View Camera
          B1102 31 [009] - No Signal
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 68
                    Mileage: 3681 km
                    Date: 2017.05.23
                    Time: 19:09:18
                    Voltage terminal 30: 12.6 V
End----------(Elapsed Time: 01:27, VBatt start/end: 12.7V/12.6V)-----------
