Passenger airbag sensor - how easy is it to get to?
masterfrodo
267
8
As per title. Mine is throwing an error, and it seems to be the passenger side under the carpet.
Is it easy to get to - googling it mentions cleaning it with contact cleaner
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,198
1,037
Kent
Remove seat
Unclip door sill trim
Peel back carpet
Unbolt the sensor from the floor plate
Unclip cable
Done
Sent from my SM-G960F using Tapatalk
maciek.snow
61
9
Poland, Krakow
I would try checking the airbag connection plug under the seat first. And cables under the carpet wuld lead you to the sensor. It might be a loose plug while adjusting the seat position. Its easy to get to it ; good luck
Wysłane z mojego SM-G930F przy użyciu Tapatalka
masterfrodo
267
8
Is there any way of getting to it without removing the seat - maybe cut a piece of carpet?
Thai-wronghorse
Dec 3, 2015
2,198
1,037
Kent
I've heard of people slicing the carpet open but it's not something I'd do.
masterfrodo
267
8
If I do slice it open, which side of the bar is the connector located - front or back of the bar?
Thai-wronghorse
Dec 3, 2015
2,198
1,037
Kent
Front of seat rail, you'll also need to cut through the thick sound deadening and risk cutting the wiring beneath.
Seriously just whip the seat out, it's only 2x 13mm nuts at the front of the seat base and 2x T20 torx screws on the rail covers at the rear.
