Positive boost deviation
ian_jobson
272
Medway towns, Kent
ok so itsover boosting STILL!
it has standard mapping, ramair induction (with feed and silver casing off at the mo) and forge 007p
ive tried maf, n75, coolant sensor, (cant see any leaks but...)
what logs on vag com should i run?
where should i look for a leak?
dump valve is new too... its all getting to me now ive sent best part of 180 quid trying to get it boosting right and it just keeps going back to soft limp... :confused:
p.s when its not hittin limp mode like if i clear the error itl run for 2 3 mins b4 itl hold 8 psi and not drop off in 3rd/4th hence not thinking theres a leak :s
ian_jobson
272
Medway towns, Kent
well heres 115 and 118.... please tell me it means something to you guys :lol:
PHP:
Sunday	19	March	2006	09:57:07
6K0 906 032    		1.8L R4/20VT SEA    0002
	Group A:	'115				Group B:	'118				Group C:	 Not Running
		RPM	Load	Absolute Pres.	Absolute Pres.		RPM	Temperature	Load	Absolute Pres.
	TIME					TIME					TIME
MARKER	STAMP	 /min	%	 mbar	 mbar	STAMP	 /min	°C	%	 mbar	STAMP
	1.34	2000	145.1	1560	1370	0.75	1880	14	85.9	1150
	2.44	2240	151.1	1500	1430	1.87	2120	13	52.5	1550
	3.69	2520	147.4	1470	1450	3.04	2360	12	21.6	1440
	4.84	2800	139.8	1480	1430	4.32	2640	12	22	1440
	5.94	3080	136.1	1480	1420	5.44	2960	12	21.2	1420
	7.14	3360	129.3	1470	1410	6.54	3200	12	19.6	1410
	8.24	3640	121.1	1470	1400	7.65	3480	13	19.6	1400
	9.55	3920	120.3	1480	1390	8.84	3760	14	20.8	1400
	10.87	4280	116.5	1480	1370	10.25	4120	15	20.8	1380
	12.04	4600	115	1490	1340	11.44	4440	15	16.5	1350
	13.05	4840	112.8	1480	1330	12.54	4720	16	13.3	1340
	14.24	5120	109.8	1500	1320	13.63	5000	17	10.2	1320
	15.57	5440	106	1510	1310	14.85	5280	18	10.2	1310
	16.76	5720	101.5	1530	1290	16.22	5600	19	10.2	1300
	17.94	6000	98.5	1480	1290	17.34	5880	20	10.2	1290
	19.04	6200	96.2	1450	1260	18.44	6080	21	10.2	1270
	20.25	5520	13.5	1000	1220	19.65	6320	21	10.2	1240
	21.54	4800	7.5	1000	1070	20.83	4880	21	0	1090
	22.73	3120	9	1000	1050	22.17	4000	21	0	1060
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
N75 duty cycle seems really low.
I wonder if anyone has adjusted the wastegate actuator? Can you take some measurements to compare to another ibiza?
