Right guys, got an S3, I know it's not a Leon but thought I'd try here since its the 210bhp engine.
Right, so the problem is, the car was boosting fine untill the other night, it would peak boost then suddenly drop and start giving a judder. The next night it got worse and started to get juddery even before the peak in boost. Went into the shops, came out and the car would start but idle very low around 300 revs and when trying to rev or pull away the car would cut out.
I had noticed a few days previously that the pump started making loud noises when primeing. My mate checked the fuel return pipe and there is no pressure coming through the pipe atall. The pump now makes no noise atall but the car has started since the pipe was removed and put back on but the symptoms just started again.
In folks opinions would you think this means a weak pump?
