Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
leon cupra will remap a little higher due to ko3s turbo, usually between 210-220
Nice power, but look at the wheel output, 8 bhp more than mine but 15 bhp if you look at the lottery number! I trust the wheels figure more.
Yes I do take the temperature point, not sure what my actual temp was, it says min 16 max 30? It definately did not vary that much on the day?!?!
A quote from this article "Another difference that can occur with gearing comes when there is a 1:1 gear ratio available. Most rear-wheel drive gearboxes will have a gear that is 1:1--typically this is fourth gear, but in six-speed gearboxes it is often fifth. In the 1:1 gear in many gearboxes, power is not actually transferred through a gearset; the input and output shafts are just locked together. This eliminates the losses through the gear teeth, and results in a higher power output in that gear."
