you will be fine mate. they sure do fit, i think it was the middle sized one. have a quick search, i posted a few photos up of which bolt to remove under the dipstick area. The autometer oil tempsender will have a long thread, but so long as you use PTFE tape, just screw it in until its reasolably tight.
not sure about pressure one though, theres only one hole, unless you can use the pressure sender for the temp also? it will be tight as i think pressure senders are quite tall
