I had bleed the master cylinder and the front callipers, it wasn’t until I ran through the abs pump bleed routine that I got any pedal firmness back. So if you have some pedal then it might be a normal bleed you need or maybe a fluid change?
I can feel the abs releasing the brakes on the damp surfaces Sunday afternoon, but it isn’t anything dramatic at the speeds I was doing. If your abs pump wasn’t working you’d have lights or codes flashing up I think. Does you’re light on the dash come on and then go off? Like the mot guys will look for?
In the Midlands so you’re a bit far away.
I haven't had a chance to bleed the master cylinder since I bled the calipers individually, but bleeding the nipple furthest from the bulkhead has always had a pretty dramatic effect. I'll have to get the girlfriend to help next week.
I've bled the whole system twice myself, had two garages do it and then I wound back the pistons with the bleed nipples open to get any remaining air out of the calipers, but there's still a lot of inconsistency in the pedal. Lots of people suggest it's the master cylinder seals, but having stripped and refurbished one, they're tougher than people think.
No lights that I can remember seeing on the dash, so at least it looks like it'll pass the MoT. I don't have a scan tool though - and every job that goes by I start to feel it would be worth the investment.
I've got family in Cheslyn Hay, so when this Covid mess is all over... Mind you, if I haven't got the brakes sorted by 2023 I think the car will be in a ditch somewhere - possibly in suspicious circumstances.
