Hi all,
when changing rear pads and disc ps on my 2015 fr st 184 do you have to remove both parts of the caliper to change the discs?
I used to be able to squeeze the disc past the caliper part bolted onto the hub assembly on my Audi A3, so wondering if this is the same.
further reason for masking is that it’s suggesting you need a special splined tool to undo the bolts and i don’t have this tool ...are there any alternatives ?
thanks for your support
