Hi all
One of my rear passenger doors won't unlock from fob. Can hear it clicking. Will only unlock from inside.
The anti highjack thing is not on.
Hope someone can help as been told it will fail an MOT.
Thanks in advance.
Paul
Hi all
Thanks in advance.
Paul
I took the inner card off. I couldn't get the whole surround off. A bit fiddly but the secret is to disconnect the door handle. Took an hour to get it apart and 5 minutes to reassemble. Not difficult but good luck.
This was the one I saw, lots of positive comments on there too, I have 3 doors that do the same, only my drivers door works, I might give this ago, haven't got much else to do at the mo
Don’t use wd40. You need to lubricate. Silicon spray is your friend. Wd make one with a tube. I’ve done this to all 4 locks. I still have an occasional problem with passenger rear during cold spells but a squirt more of silicon usually sorts it.
