Rear seat rattle
Miller888
8
Hi all,
I have noticed a rattle from the back seat, drivers side.
When the seat is down there is no noise so I think it’s coming from the seat catch to lock it back in place. After speaking to a dealership, they said they would not cover adjustments as this is not a fault as it all works.
Anyone else had the same issue?
Si
/dev/null
1,649
101
Hi all,
Si
Tell them to **** off. It's not an "adjustment", it's fixing something that isn't as per the design.
Reactions: Miller888
Miller888
8
Tunbridge Wells. They have been excellent with everything else though.
I found where the rattle came from in the end, which was the catch for the seat, the mechanism inside the seat hitting metal link. Put some masking tape around it and no more noise.
Thanks for your replies
Reactions: Leon097
Leon097
39
16
The Netherlands
I have this rattle as well on my Cupra ST, not sure if it’s coming from the driver side, but I’m sure it’s coming from the rear seat. Did you remove the seat? I want to put some deadening as well so would like to know if the process of lifting the seat (Alcantara) is the same as on other topics on the forum.
Miller888
8
Didn’t remove the seat, just folded them down. I found it was the the hook inside the mechanism, which if I prodded made the same noise so taped the metal catch it locked into which seemed to have prevented movement. Seat still folds fine and locks back into place
Reactions: RichardTaylor
Seriously?
1,246
837
