Replace Cam Follower?
Jammy78
422
Hemel Hempstead
Hi,
I've just checked my Cam Follower, and it looks ok? I have a replacement, so is it worth changing or shall I get a refund?
Tbh, I'm not sure what a faulty one looks like?
It's from a 2007 Cupra with 40K miles:
Replace or leave?
belfastchris45
445
belfast
Hi,
Replace or leave?
There is clear wear there. You have broke through the top black coat. Definitly replace it. It's only a few quid.
May 25, 2008
1,919
S.Wales
www.seatcupra.net
Since you have remove the cam follower...
You may as well replace it as the new follower will have more coat protection on it than the one you have removed.
Just reminded me I need to check & replacement.
Jammy78
422
Hemel Hempstead
Yeah, you're both right.... might as well replace now I've taken it out!
When putting the pump back, should it be hard to push it back in? It feels like the Cam Follower needs to be pushed back futher, but it wont?
belfastchris45
445
belfast
Yeah it's perfectly normal for it to be hard as you need to push the spring in.
tonto
1,265
plymouth
there is obviously wear there. i would replace.
for the sake of a few quid, my car is now on 23k i will be replacing it when i service it next / go stage 1 (in the next few weeks) and therefor every 10k service after.
