Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
surely running without the vac res is dangours, if the engine cuts out you'll loose most of the brakes. with the vac res in there you should still be able to use the brakes effectivly for at least one push of the pedal, Or is that a different vac res?
Nothing to do with the brakes, so no danger no.
totally different vac reservoir mate.
This one purely assists with the dv/n249.
What I want to know is does the vac res. do anything without the 249 operating?
The N249 is the last valve in the chain before the reservoir, isn't it?
