guys I would like to install the lights under the doors, as far as the front ones are concerned, it should be easy since there are the door control units with the relative PINs which should be the same as the door sill lights; for the rear doors it is much more complicated as they do not have door control units; I tried all the cables that reach the door switch but they are all low voltage and I can't find which one turns on the ceiling lights and gives the door opening signal. anyone have any ideas?
