reverse light
helms
Console Race Car Driver
Jan 30, 2005
492
Basingstoke
Hi guys and girls,
reverse light stopped working, naturally done the usual and changed the bulb, but its still not working, checked all my other lights, all A-ok.
It was working every now and then, sometimes came on, sometimes not, but its just dead.
Are there any checks i can do to see what the problem is? I've checked fuses, well most of the ones ive been able to find, and they seem ok.
Any other suggestions?
Andy.
bully
47
Rochester kent
hello helms ! recently had this problem with a friends astra at first tried the obvious but did'nt work then it turned out to be a reverse light sensor which is attached to the gearbox, it's a bolt about 2 inches long with a small connecter on the end !
bully
47
Rochester kent
on my friend's astra it was in the centre on top of the gearbox ! it might be best if u try to get hold of one first,[ breakers maybe ] then u'll know what it looks like ! but i would double check the obvious before u go down that route !
