DPJ said:Saul & Pabs........ A visit to your private roads are needed!![]()
And you expect to prove what from this? Not like you're gonna be able to tell what difference there is - unless you car is VERY down on your estimated power?
Pabs said:Then why are you worried about your power being down? How low is it compared to what you think it should be?
Pabs said:And you expect to prove what from this? Not like you're gonna be able to tell what difference there is - unless you car is VERY down on your estimated power?
DPJ said:Sorry if you took this the wrong way Pabs, it was said in jest. I was only going on from Wilko's suggestion a few posts ago...............
Pabs said:you are low then! What spec you/saul running?
Pabs said:............My logs all look very similar to yours to be honest - my car doesnt feel down on power as such
Pabs said:.........Whats the bhp/whp conversion method again? If I have done it right it puts my figures somewhere in the middle of yours and sauls..
Pabs said:Surely you can't blame revo? If its the same map as Saul/me/others then i dont see how changing to APR and the additional cost involved making it worthwhile?
Pabs said:hmm ok - so maybe my figures are a tad optimisticLOL
However, i'd also think that Revo's estimates for stage 2 output would be a bit high if this was the case - they say up to 15% more power than stage 1. With the old 4 bar FPR giving 217bhp, only getting 210 on yours/223 on sauls means that stage 2 is no better than the old 4bar program?
Martyn said:Dave, have you got any logs for the MAF? Will be good to see if the airflow is your problem.
Martyn said:Dave, those MAF figures are very good for a K03S.
