I’ve just noticed a slight notch about 3/4 up the pedal movement. It feels more prominent on way up but can sometimes feel it on the way down. It has no issue getting into gear and the clutch isn’t slipping. The car has had a lot of work done on it early this year as the pedal was sticking, due to a failing master cylinder. Before this it’s had flywheel, clutch, slave cylinder and pedal assembly (as they couldn’t find the problem, so it was a case of change things until it works!) Since all this work it’s been absolutely fine and as far as I can tell this notch is new. I haven’t had chance to poke my head under the pedal yet. Anyone had/has anything similar with their clutch?
