Smoke on idle through vents
Kwok
114
Anyone had smoke coming through the air vents in a deisel leon? Can't seem to find where it's coming from after it being in a few different garages.
bigRobbo
sounds light waters getting on your header matrix?? tried having a look where your pollon fitter gos?? for any water?:)
Kwok
114
Is that bad mate? I'm gonna have a look at the pollen filter tomorrow. Fed up with the smokey fumes everytime I use the heaters.
Have you had this problem before?
Thanks for the reply
Sent from my GT-N7100 using Tapatalk 2
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
Do the fumes smell oily? Maybe you have a small oil leak from the engine and the hot engine burns the leaked oil that dribbles down the hot engine and makes a bit of oil smoke. This could get in through the heating/ventilation.
I doubt that it's exhaust fumes because you would hear if your exhaust had a hole in it.
bigRobbo
no coolant is there could have a small leak your coolant level okay? and what dose your smoke smell of ? and check all your rain water run off points around bottom of your windscreen ?? they can block up and allow water to enter the heaters is it only when your at a stand still?? :)
Kwok
114
It smells just like the fumes coming out of the exhaust. Really fed up with it. I can smell it outside the car too.
bigRobbo
check your exhaust manifold for leaks on the black can be leaking and bin sucked in by ya heater fan ??
hope this helps pal :rolleyes:
Kwok
114
Thanks buddy, will have a hunt about the car for it tomorrow
bigRobbo
i had a leon before it had one really small hole in the gasket and was leaking in to the cabin so have a good look pal :)
Kwok
114
Ah right. Was thinking of getting an egr delete done too. Is the ibiza running ok now
