Speed Cameras locations on Leon mk 3 nav
chrisRibiza
1,194
51
There's a long thread on this already so to cut a long story short, they can't be added.
Julian1977
174
You're supposed to stick with the speed limits, mate!
Ah, you drive a Cupra, so you can't... :rofl:
golf gti dude
Lottery win needed.
Sep 2, 2012
512
Chester/Shanghai
On my old rcd510 unit on my passat I could add them, bit disopointing that the seat hasn't got the facilty. Wonder if you can add them on the golf r sat nav?
thefunkygibbon
Mk3 Leon Cupra 280
Jan 9, 2012
424
you can import POI it seems from one of the menu options. not tried, so don't shout at me.
although i'm assuming the best you'll be able to do from them is to see them on the map as you're driving, rather than being alerted.
better than nothing i guess.
now to find a decent speedcam POI file to try to import. pocketgpsworld used to do a good one back in the early days of GPS, but now they want money for it as a subscription.
JK1
531
Bedford
If I remember correctly in the early days someone did try to import several thousand speed camera 'POIs' and it just crashed the NAV System and rebooted. It's not meant for that volume of data.
jimiC
314
South Derbyshire
that looks like it could do the job but would you trust a website that hasn't been updated for 3 years, has 8 year old screen shots, a latest software version that implies only fixes for bugs that occurred 5 years ago and a Support page link that is broken? seems a bit of a risk to land $40 on it.
kazand
Is powered by Medtronics
Jun 6, 2010
4,138
73
Brum
No chance,the sat nav is pants enough as it is ......... :(
golf gti dude
Lottery win needed.
Sep 2, 2012
512
Chester/Shanghai
True I'm very disappointed with the nav, I'm sure the screen is the old lcd screen as well as the quality is blurry in my opinion
Madefeld
22
Pop over to the Golf GTI mk 7 forum where there are instructions on how to add speed cams. It worked fine for me and my adding the cameralert app to my phone using the same database I have sound aswell.
I would copy the whole post but as I'm a newbie I can't put URLs in my post.
This is the forum though.
GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Infotainment, Electronics, Navigation, Phone (Audio / Video / Electronics)
Madefeld
22
There is another post on the forum which has pictures of the german website and what to enter where. It also gives details of the cameralert app which I have to say is really good (if you set the output on it to bluetooth it interupts whichever source you are listening to).
Madefeld
22
I've copied the post and removed the links and the screenshot to let me post......
Right, here goes. It's a bit long winded but I hope it draws together 24 hours of trawling the internet, trial and plenty of error, and saves others a few hours. These are the Mac instructions….the PC ones are the same, minus the Firefox, CSV filetype and unzipping info. My main issues were Mac incompatibility, and subsequently lack of POI space in the Nav unit.
Mac Users - Use Safari but follow the unzipping instructions on the site
Choose CSV files (I used Navman/Mio CSV)
Untick pMobile files
Select UK Consolidated by type
No voicepack required
Repeat the process but this time select UK speed zoned complete
(This will give you grouped camera types and individually labeled cameras)
Notes: The Discover Pro Nav only allows ten POI’s. If you’ve already used up some POI’s eg with petrol stations you’ll have less space for speedcams, and vice versa. Therefore you need mainly to use consolidated camera types eg Gatso, rather than individual speed cameras eg 30, 40, 50 etc in order to reduce the number of POI’s. It’s worth downloading/uploading all types if you want to have the option to choose at a later date as you can select in the Nav unit – it’ll save having to re-do at a later date - but make sure you have the consolidated groups uploaded.
I've only tested audible alerts with an iPhone - I don't know if it's possible with other smartphones. Input from others appreciated. The app is called CamerAlert so please see if it's available and test.
Download Speedcamera database from PocketGPS (there are others)
LINK REMOVED
Using Firefox (not Safari) go to:
LINK EDITED www volkswagen de/de/navigation/ ... mlung html
Click on the orange button on the right.
The next window is where you upload the files into Nav Companion, screenshot below.
IT WONT LET ME PUT THE SCREEN SHOT IN
First browse button – choose a CSV file eg Gatso cameras which would be called pocketgps_uk_gatso.csv
Middle box – give it your own POI name eg Gatso
Work your way through the files until you’ve uploaded all the camera groups and individual types that you might want to use now or in the future.
Click on the orange button at the bottom right of the screen, and keep clicking the bottom right hand buttons (!). It’ll create a folder called Meine_POI_Sammlung which will be zipped in your downloads folder.
Firefox should unzip it automatically, and create a folder containing PersonalPOI and a file called metainfo2.txt
Drag these two items PersonalPOI and metainfo2.txt (not the parent folder) onto a clean SD card.
Now go to your car…….
Keep the ignition on so that the unit doesn’t go into sleep mode.
Main menu – swipe across to set up and select it – insert SD card.
System info – Update Software
It gives you a prompt about POI’s to which you say next.
It takes about 20 seconds to upload.
Message saying system will be restarted – Ok – Now – Restarts
WAIT – It all goes black for about 2 minutes and says Infotainment system is switched off on dashboard.
Now go to Nav…….
POI’s – Other POI’s
Find category
My POI’s…..and you should see your speedcameras
To set up speedcamera POI’s in Nav:
Nav Setup – Map – Select Categories
You can store up to 10 POI’s – a combination of cameras and other POI’s.
To set up audible warnings (this is a workaround, slightly makeshift but better than nothing. It's a work in progress):
Download CamerAlert for iPhone from App Store
Sync it to your PocketGPS account to install the speedcamera database
In Settings – Camera Warnings – Audio Route – Select the Bluetooth icon (far right)
It’s pretty crude, however its alerts play via Bluetooth through the car’s audio, and use the same database as the one you’ve just installed in the Discover Pro. The downside is that it doesn’t know what route you’re on so you get alerts for cameras nearby - the default range therefore needs to be set quite low. I’ve only just started testing this so don’t know how effective it’ll be over longer journeys, but it’s picked up every mobile camera spot in a 10 mile radius where I live. It works when the iPhone is plugged in via USB or unplugged.
