Stance drop links
Jul 12, 2019
8
Hi all
Is anyone using stance shortened drop links?
My Ibiza is lowered about 40mm on springs, and the standard links had play and the other was bent so I replaced them with the above mentioned.
Once fitted they had a hurrendous knock and kept coming loose. We have changed the nylon lock nuts for new ones and it hasn’t came loose since. There was marks on the chassis where it was rubbing. We have ground down the end of the treads on the links and it has improved but it’s still knocking on bumps??
Has anyone had issues with these drop links???
BocaBill
115
58
Got the Stance shortened links on my Boc, Dropped 45mm on the front, no issues. Any lower than 35mm on oem links will give rubbing on ARB.
