Stereo triggering central locking ?
Feb 25, 2020
8
Hi all
Bit of an odd one this.
The stereo on my leon appears to be operating the central locking intermittently, From cold start the doors lock as they should when i get up to a certain speed.
However and at no specific speed or any other obvious reason the stereo switches off and the central locking unlocks the door.
I then turn the radio back on which may only be for a second or two, maybe longer and the c/l is activated or deactivated, all the while the stereo pleases itself i it stays on.
I f I purposefully switch the stereo off from start up, The c/l does not activate or deactivate after the initial speed set activation.
Another thing to add is that the sequence of events when i turn the ignition off varies from interior lights on and stereo off to no interior lights and stereo on.
Has anybody come across this or have any ideas why this is happening ?
Car is a 55 plate MK2.
Rusty2k
710
133
Sounds like a faulty ignition switch or wiring to/from the switch. Do you have any diagnostic equipment or code readers?
Reactions: Dacrondive
