had the same
problem mate when i done mine you seam to get the
problem if your running the ko3 and not with the k03s reason being is that there are two pipes comeing from your turbo you have to block the 1 of that comes bk up to return where you had the n112 ect befor but leave the one that goes to the n75 as it is this fixed my
problem as that pipe vents the bosst some how mate if i can be any more
help plz ask
Thanks for the reply yellow_fever, I am a little confused mate, I think you are referring to the N249 valve being done? I should have put down my spec down as I have not done the N249 mod, I am running a revo remap and a forge recerc DV and that's it. I was running a hurricane filter but took this of a month ago, I am running a standard filter in the standard air box......could this be the
problem, do you need a free flowing filter or is the standard OK to run Revo.
At the minute the car runs fine apart from the lack of boost, I had a look this morning on the way to work and it seems to boost to 14-15psi then dropping to about 10psi then I tried to accelerate in 5th gear on the motorway and it boosts to 20psi but drops quickly down to 10psi again. 20-21psi is what I normally tend to boost to.
I have checked all the hoses and everything appears to be fine, there are no error codes on vagcom and no engine check light on the dash.
I have disconnected the MAF and it runs the same.
The dump valve doesn't seem as loud to me also, but this is probably the fact that there is less boost.
From what I have read in other threads I am tempted to change the N75 first.
Any advice would be good chaps as I have a new car coming in a few weeks and need this one sorted asap.
Cheers,
Brian
