TFSI : what fuel do you use
ALTEA4
71
32
So after being advised to use shell optimax or tesco momentum I've come to the finding that my car actually runs better on Asda 95.
Since buying 18 months ago , 95% of the time used a super of most types with varying reactions from the car.
Sainsbury's fuel : the car hates it : patchy reving , pinking.
Shell optimax : no performance or mpg increases.
Tesco momentum : has been the fuel of choice, definitely an improvement over either of the above.
Well that was until 3 weeks ago when I needed a full tank for a 250 mile trip quite urgently.
Asda is my closest pump so thought , just for once it won't do any harm as its a motorway cruise.
I'm a convert , I've filled at 4 different Asda garages around the country and the results are the same, good throttle response , more aggressive engine note, more whoosh from the dv+ and better economy.
Anyone else found the differences in fuel?
Philip Santi
96
30
I've only put Momentum 99 in mine since I've had it - not tried anything else, but I still need to pull my finger out and finish the major servicing so I know it's probably not running at it's optimum at the minute - once done, I'll give the ASDA stuff a whirl.
