Cupra 180 AUQ “the shed”
Sl1ced
797
404
I thought it was a pretty common bit of kit
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
Can you not use a straight pressure test and just listen for the air escaping ? - As a matter of interest I had a leak in the seal around the IAT sensor and one of the vacuum lines under the inlet manifold (going way back)
Sl1ced
797
404
I have none of the equipment to pressure test.
Connor H
1,015
498
Essex
Something I’d love to do but don’t even have a compressor, closest thing I have is a bicycle track pump which admittedly goes to like 140psi
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
I purchased a basic pressure tester off of ebay and a car tyre inflator from amazon. Seems to work well enough.
You only need 15psi Connor ..........140 might give you eleventymillion horsepower for about 1/3rd of a second though :)
Reactions: Connor H
Sl1ced
797
404
So the timing belt is starting to make me itch, only cos I know it’s due. AMD will do it all inc pump pulleys and tensioner for £369 fitted. I hate paying someone to do stuff like this but I don’t trust myself.
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
AMD have done mine 3 times now - so far no issues. Sometimes its best to bite the bullet and just accept that there are some things you cannot do....
Reactions: Sl1ced
Sl1ced
797
404
Well.... got home an hour early so decided to do my forge TIP... what a pain in the ass that was. Fml it also sits in a slightly different angle to stock, is this normal?
I plan on running a vac line from the lower insert on the tip (grey covered pipe) to its source so I can ditch them buzzin metal vac lines too they seem to get in the way.
Also confession. My TIP to turbo jubilee clip broke and I got angry and threw it in the bushes... I forgot what size it was can anyone help? I don’t wanna take it off again.
One day I will upload some pictures too
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
The aftermarket units do sit a little different and most will need a little trim (read adjustment). I have a BAM 225 so not sure on how vac lines run on the AUQ.
From memory the jubilee clip is around the 50-70mm size.
Sl1ced
797
404
Yeah buddy 60mm stick in my head for some reason, I got it second hand so I assume it was already trimmed etc,
On the right hand side of the engine there is four thin metal pipes all moulded into one. They piss me off lol
Sl1ced
797
404
No mate ima eBay one lol. Lockdown mk 2 strikes
Sl1ced
797
404
It’s cool got a pack for £2. Winner. Noticed oil seeping out what appears to be The top left corner of the rocker (TIP side) but I was looking at doing a gasket anyway.
Sl1ced
797
404
So did some work today. PVC simplify, removed the skanky metal vac pipes, replaced some more perished hoses, replaced a cracked fog.
Of the back of it is the hockey puck meant to be a one way valve? Mine flows both ways . Next to mount my catch can....
Also need to replace a rocker gasket by the looks of this
Oh and I took a photo....
Reactions: Connor H
Sl1ced
797
404
Been working on some creative DIY
Got some sanding, and a neat rubber trim to apply.
I’m too tight to buy a heat shield
Reactions: Connor H
