There in the spary shop now
moditsteve
I have sent my 54 reg fr fog light surrounds into spray shop to be colour coded.
I have seen someone who had them sprayed on there car of net and looked brillaint.
I will post some pics when i pic them up on Wed.
:p :clap:
tommmineh
1.2 POWER
Feb 28, 2005
721
Sheffield/Rotherham
:p :clap:
I have a set waiting to be sprayed up too!
Just building funds to get all the other stuff I want sprayed at the same time :rolleyes:
moditsteve
i pick them up tom midday so will put pics up wed afternoon :D
Bunnin
Stealth machine
a lil sub question while we're on the subject of spray jobs
Im due to collect my bump strips n eyebrows tomorrow all sprayed up n smoothed.
i took off the originals tonight which leaves u with the sticky (annoying) bits to get off :censored:
Anybody gotta a quick n safe ways to get it off apart from maybe a bit of elbow grease or pressure washed ??
gazjones
when i hadmine done the put the car in the spray booth then heated it up to 60 degrees so pannel temp was about 30 all came off bar one little bit witout leaving any sticky stuf on. so using heating up the stuff wont harm the paint as long as you dont go ott
orca
412
N Kent
www.bdmlr.org.uk
Lighter fuel (petrol not gas) work a treat
andy_gdon
494
there is stuff from 3M that i always use for removing the badges etc-good gear.
were you not left with holes for the rivet while the rub strips were away?
I had mine painted on the car which was an ok job-did for the interim. Car goes in next tues for: Removal of rub strips (holes welded over), skirts modified and smoothed into body, MS Design front splitter modified and moulded into bumper, bump strips on front/rear bumper removed and smoothed, bonnet resprayed.
Should be very euro when i get back from Cuba!!
gazjones
did you cut the eyebrows at all in the end bet side strips look loads better!
andy_gdon
494
tommmineh said:
That'll look sweet ^
I'm intrigued to see what it'll look like with the bump strips smoothed into the bumpers, are you not tempted to do the plate recess aswell?
dunno - ive nowhere to put the plate then as i dont want to block the Forge FMIC.
the bump strips on the bumpers have to be cut out then smoothed over as they sit out too far! Not an easy job but should look good!! Pity im selling it soon!
look here...just down the page is a photoshop courtesy of stocky, showing what it will look like!
http://www.reallymeansounds.com/forum/showthread.php?t=39237
