If anyone has had any throttle valve issues and managed to solve them or have any ideas on how I could solve mine, could you please read through this and give me any advice......
Anything is appreciated... This has been going on forever.....
OK then, basically under full throttle (full boost) my throttle only opens up to 48%. I should be above 95%.
I have checked Lambda readings, MAP readings and all the wiring to and from the throttle.
Also recalibrated the throttle pedal.
I have exchanged the ECU, with other ones and put everything back to stock to test the throttle valve issues but the issue persists.
Just for info, I currently have all the hardware for a stage 2+ tune and am running a conservative tune. Also have WAtermeth but it is currently all turned off.
I have been to two different garages and no one seems to be able to figure it out. The last garage I went to thinks it can now only be something electrical, but sensors are not showing any faults and all the wiring was checked and everything is ok on that front.
If anyone has any ideas or has had a similar or even the same issue I would really really appreciate any help even if it seems trivial... I just want to have my car back..... so any help would be greatly appreciated....
Thanks... m.001
Thanks... m.001
