Torque Damper
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
Would a mildly modded 1.8T (200-250bhp) benifit from an engine damper?
Simlilar to this. Could it be a viable alternative to uprated engine mounts?
Beaker™
Nov 21, 2005
1,900
C:\UK\Glos
yup.
I'm sure you could fabricate something similar to the evo pic you've posted though.
Ahh i see, cheers for that. As for the damper, might be worth a look i've seen dampers mounted between the strut brace and rocker cover before now. Would be easy enough to do.
Nov 2, 2004
9,335
South Wales
You could probably do it off the bit where the engine code stamp.
cupra_matt has this off his strut brace and to where the OEM charge pipe brace is.
