I'm not really clued up on turbos so was wondering if I could get some answers how can I tell when my turbo goes also should the turbo be quiet prominent when driving or pretty quiet ?
Would a diagnostic reader pick up on it ?
Depends how it fails really mate. If it's a seal failure (most common failure) then probably a lot of smoke from the exhaust etc. If the hub fails at full whack ( not that common luckily) then i've heard people who have experienced it say it's like a grenade going off under the bonnet! Not suprising really when you realise that turbos often have speeds in the region of 80,000 to 120,000rpm! Thats a hell of a lot of energy built up if a compressor wheel etc fails.
On the LC/LCR then the turbo should be easy to hear when boosting, should also be able to feel it kick in and shove the car fwd at 2000-2500rpm. Not sure about how the diesel leons sound tbh, never driven one, but the turbos on diesel cars i have driven are definitely not so noticeable.
If you put your foot down with window open can you still hear the slight whistle of the turbo?
I would have thought so yeah. Do you think the turbo is working at all? Or does it feel like it permanently in limp mode? What rpm does the car start to pull at? If turbo is working properly then it should be 2000rpm ish. If in limp mode then it will feel dead until 4000rpm ish
Yeah it's quite possible that the new bonnet seal has made it sound quieter i guess. As long as you can still hear it spinning up and it still pulls hard from 2000-5000rpm then it sounds ok buddy. Maybe get it on vagcom/vcds to just check it out. You getting a revo remap mate?
Yeah it's spinning at about 3000rpm ? Yeah hoping to get one sorted in a few weeks just looking around to see what the best remap is ?
I've got the LC 180 with the AUQ engine, which i'm guessing is the same as yours. You definitely won't be disapointed with revo stage 1 mate. I had mine done a couple of months back and the diffference between that and standard is huge! It pulls so much harder in every gear, totally transforms the car. Goes from 180bhp and 173lb/ft to 210bhp and 240lb/ft!
Take the plastic cover off of the top of the engine and then the 3 letter code should be stamped on a little piece of metal just on the front of the cylinder head. Either that or there is sticker underneath the carpet in the boot which should tell you all of the car info too. If your car is made in 2001 or after then you can pretty much guarantee that it will be an AUQ
