Turbo flutter
deanodaf
35
Rathfriland
Hello, I have a ibiza fr with a 150pd turbo fitted. The turbo is about 6 months old and recently started leaking some air on boost and then flutters on lift off. Fitted a darkside intercooler with egr valve cooler and delete and it has not changed.
Here is a video to show what I mean
youtu.be/4hl3eoDkWpg
Any ideas?
Badger
2,888
7
Newcastle, Staffs
That noise is how a VNT dumps the boost when you lift off the accelerator. It shouldn't be that loud though unless you have a straight through exhaust.
It sounds like the leak could be the turbo exit pipe, but check the whole system for leaks. Have you had a de-cat pipe fitted?
deanodaf
35
Rathfriland
Yea, I have a miltek de cat fitted. I will check the pipes again at the weekend . I thought it could have been leaking through the wastegate but wasn't sure
Badger
2,888
7
Newcastle, Staffs
Diesels don't have a wastegate, they have VNT or 'veins'. So that isn't leaking
The Miltek does make the 'pigeon noise' more louder. I wouldn't worry to much unless you have a exhaust leak?
deanodaf
35
Rathfriland
I see. I will check the pipes anyway and see
Yea not concerned about that noise, just the flutter sound had me worried.
