tyre pressure warning light
dan1
Hi all,
My tyre pressure warning light has come on, I have checked the tyres and they are all correct psi.
Is there a reset button on the 2014 leon, I have had quick look but cant see one.
Dan
kazand
Is powered by Medtronics
Jun 6, 2010
4,138
73
Brum
Hi all,
Dan
Think its in the car set up menu. You are no longer allowed to have anything as simple as a 'button' , haven't you heard? :D
dan1
Ah ok thanks,only had the car couple of days I will have a look in the menu as you say, im hopeless with things like this the much prefer just the button :D
kazand
Jun 6, 2010
4,138
73
Brum
Sat in it now, first turn on infotainment system. Then press 'car' button - 3rd down on rhs- then press 'setup' - middle of screen, at the bottom, then select 'tyres' -2nd down- then 'calibrate' , finally 'confirm'.
Not complicated at all. No. No need for such a basic thing as a 'button' . :rofl:
Please note we have the 'upgraded' sound system with nav, so yours might be different, perhaps less (or more!) levels. Who needs a PS when you can 'play' this all day......
dan1
Sorted thank you for your help, wasn't as difficult as I thought it would be I better start getting used to all this technology lark lol
dimucci
14
The warning is very "late", in my experience. I had a slow in one of the rear tyres (calibrated at the recommended 29psi). A warning came up and I found that the pressure was 24psi!
