Hopefully someone might be able to suggest something else I can try here!
My front windscreen washers (both nozzles) have stopped working properly. When I pull the lever to get them to spray I get a tiny trickle out of the left one, and a couple of jets out of the right one, but they both used to produce a big spray of washer fluid.
I can't see anything stuck in the nozzles, and it seems a bit odd they'd both get clogged at the same time. I've had a poke at the nozzle anyway and it hasn't helped.
Any idea what could be going wrong?
I've definitely not run out of washer fluid, I only topped it up with concentrate recently when the weather got colder. The rear windscreen washes fine and the wipers (front and back) all work fine.
Is there a separate pump for front and back washers?
The nozzles are actually part of the bonnet, and the only tube I can see going into the bonnet (when open) is on the driver's side. Doesn't seem to be leaking.
I'm kind of out of ideas what else to look at, so suggestions welcome.
Otherwise I guess its off to the garage.......
