What cone filter
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
I think it was £49 + VAT. Some of the odd diameters they do are more expensive though. I went for a 70mm OD neck on the filter and also bought a piece of silicone tube with a 70mm ID to fit onto the MAF (MAF is also 70mm OD). That way I didn't have to use any reducers. I've read on here that a lot of people are using the Jetex/JR filters but I wanted to try something different.
I'm also using something different for a dump valve from the usual Forge set up. I've go a Turbosmart recirculating valve. Made in Australia and I must say the machining on it feels very good.
Do you have an LCR or an LC?
I've found an 80mm one which I may give ago when my Pipercross gets tired.
http://www.merlinmotorsport.co.uk/p176/ITG-MAXOGEN-AIRFILTER-80MM/product_info.html
£69 though. Hmm..
NEOCON
Leon Cupra. I keep meaning to set up my signature but can't work out where the setting are :(
NEOCON
tOm, the one you've picked has an 80mm internal neck diameter. The one that is listed as 78mm has an outside neck diameter of 81mm and it is £49 ; )
NEOCON
No problem. I wondered why they listed them based on the internal diameter of the neck because the neck is solid metal so it would make sense to know the outside diameter because you are going to clamp over it not inside :confused:
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Indeed.
I'll be trying ITG next time :)
