What does a Cupra idle at?
robjnr
258 spanish donkeys
Oct 24, 2007
410
Bristol
Noticed that my idol was a bit lower today at 750rpm (on the line under the 1000rpm mark) I'm sure it's ment to be higher, and when i'm sat it traffic i can feel the car lumping no and again but the revs don't hunt or anything. Any ideas? I've just had a visit to the dealers :happy:
Red Cupra
Re: What does a Cupra idol at?
Just been out and checked mine, it was idling slightly higher, then I turned the AC off and it dropped down to 750, so the three of us are screwed!
vngtx
its normally between 800 and 1000 but having extra load on an engine will make it lower. you can always adjust the idle.
vngtx
id be worried if it went lower than that as the oil pump wouldnt get the oil quick enough to the turbo.
robjnr
258 spanish donkeys
Oct 24, 2007
410
Bristol
Thing is mine used to idol at ayound 900rpm but now it has dropped, only noticed it today, maybe it's the hot weather? Have no idea
-pseudonymous-
681
Vag-Com shows that my cars idle fluctuates between 720-760rpm with the aircon switched off and 800-840rpm with it switched on.
robjnr
258 spanish donkeys
Oct 24, 2007
410
Bristol
I'll have a decent look tomorrow, but i'm sure it used to idle at around 800rpm 900rpm with aircon off
robjnr
258 spanish donkeys
Oct 24, 2007
410
Bristol
Just checked and with econ off it idles at around 800-900 and switch econ on and it settles to 750rpm
HuckingFell
Red Rules
Jan 22, 2009
160
Leicester
I get the bumpy idle as well but you don't notice it unless your thinking about it. Must admit that it was slightly concerned when I first got mine, till I read a thread on here about it!
robjnr
258 spanish donkeys
Oct 24, 2007
410
Bristol
I don't always get it, i can be sitting in traffic and i'll feel quite a thud as if someone has just stampted their foot on the floor of the car,
Also my exhaust sound on idle is lumpy if that makes sense, like its not a smooth rhythm sound
