What engine code for a large port head..?
virdi
892
Middlesex
Hi all.
Which 1.8T head is 'large port'...?
My engine is obviously a BAM - Does the BAM engine have smaller ports than some of the others heads?
Feb 20, 2010
1,525
ipswich
Agu and aeb both run big port
Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
Anything Bigger than a ko4 lol do yes the ko4 hybrids also work well , all 1.8t bottom ends are the same so yes if you get a new head it will bolt strait on
Ronin225
4,652
22
Worcester
Some ADR's are also largeport and a stock inlet mani can be used if you get a transition gasket but obviously wont flow as well as fully largeport through out
virdi
892
Middlesex
Just one thing I'm not sure about. The inlet manifold has the pipe coming from the intercooler on the opposite side compared to the BAM setup.?
Ronin225
4,652
22
Worcester
A few of the 1.8t alhamba/sharans had largeport inlet mani's with RH throttle bodies but are super rare.
Other than that its aftermarket mani's
