What kills coil packs?
Double-6s
341
Hove (Brighton)
Just wondering what kills coil packs?
If you give your car a good ragging (stage 1 mapped) can the thrashing kill coils? Does how you drive have a bearing on coil pack life?
Will
big eck
3,976
Falkirk, Scotland
I was told a while ago that they raise out the head a bit under hard boost which causes the spark to jump further which then fooks the coil. Don't know how much of that is true tho.
Mart
Sh#t Happens
Dec 18, 2001
155
Surrey
From my experience, I ran my LC standard from new for the first 8 years, driven fairly hard but only after everything was up to temp.
Then I decided to do a couple of mods as seen in my sig, mainly TIP, CAI, Silicone hoses and exhaust. The car was on its original coil packs from new, but in the 2 months following the mods, every single one of the original coils failed at different times and had to be replaced and 2 of those have gone since.
It’s never been chipped, always had V-Power, puts out a consistent 192bhp on the Liquid Gauge.
So, 8 years was fine, couple of small mods and 4 coil packs gone in 2 months, another 2 gone over the next 12 months, same driving style.
Maybe the extra vibration from the engine mounts has an effect too.
Alexis27
2,206
540
Manchester
AA guy told me it was all down to the spark plugs. If one coil goes, change all 4 sparks ASAP.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Old plugs take more power to raise a spark as the gaps get wider. So that could well be a factor in coil pack failure. Combine that with the coil packs themselves getting older, when the insulation starts to break down.
A good reason to change plugs (if they've not been done recently) when the coil packs start to go. How old are your plugs, Double-6s? It's a false economy to try to make them last too long. Seat's recommended interval is 40K miles, which I'd regard as a maximum.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Will
worn (large gap plugs)
heat
age
vibration
cylinder pressures (boost)
all factors in why coil packs can give up the will to live on occasion
